We tried the settings you said from the render settings for the far field, but the problem was not solved. When we want to add or delete far field or change angle increments of far field, the program closes. It only works when I open an empty cadfeko file and add far field first and then import the relevant file. This issue occurs only in electrically large platforms.Please help us find and fix the source of this problem.
Have a nice day,
