Hello, I have been trying to make an optimization of a hardpoint. I want to optimize the weight under load applied in grey zone
I have introduced all the parameters of the optimization (Response, Constraint, Objective and design variable). But the following error appears when I run the simulation:
*** ERROR # 312 ***
In static load case 1
the compliance is negative or large -1.96593e+012.
Optimization/buckling analysis cannot be performed.
due to possible rigid body mode.
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
Could you help me with this error please, and also could you verify if the 3d model is correct, or I have to make only one volume?
I attach the hm file as well
Than you in advance
