I have been trying to simulate a sandwich panel with aluminium core, insert and carbon fiber laminate. I have introduced the following values for carbon fiber and core:
I have also defined the failure criteria in properties as TSAI. I believe everything is correctly defined, however when I run the simulation the following error appears:
*** ERROR # 144 ***
CPYRA element 155981 has singular strain functions.
Please check material data.
Anybody could help me please?
