No .h3d-file created
I was doing a modal analysis with HyperMesh. I have done the same steps as in this instruction. When I finally do OptiStruct, the solver runs without error message. At the end it says 'Jobs completed'. But when I want to see the results in HyperView, I get the message, that there is no .h3d-file found. I looked up in the folder and there was no .h3d-file created. I do not know why because there is no error shown.
It works this way: If I do not create a second load collector and set the card image of constraints to EIGRL, then a .h3d-file is created. So the problem might be something with the constraints and the EIGRL load collector. But the steps I did are the same as in the instruction above.
Can someone help me?
Greetings
Could you directly attach the tutorial pdf which you are referring?Please check whether solver writes .out file or not? If possible share .out and .fem file.
