I want to export my simulated model as a .stl-file. There should be my mistakes visualized in the exported file. Is there a way to do this? I didn't find any solution to this problem.
Thanks for your help!
Hello Nico,
You can select the model and go to the file for save selected. Then change the format of your export to .stl.
Milan Raval
Hi Milan,
Thank you for your answer!
Is it only the CAD-Model which I loaded before the casting simulation or is it the simulated model afterwards? If I switch to the analyze-mode, I can't select my casting part to "save selected".
Nico
