I have gone through the video of Using Feko, Exercise 1B: Interactive steps. However, at the end the chart text for vertical column is not shown just like the video. After doing the comparison between the two models I obtained the graph however the unit as per video is shown as dBm^2. But in my case it is shown as dBsm. Please tell me what to do? I have again gone through the steps but not unable to get this unit in vertical column
Hi Samarth,
Kindly follow the tutorial steps with the model provided to you carefully. The tutorial is for demonstration purpose only and might not have exact values as the model provided to you (as it defeats the purpose of examination).
dBsm is nothing but dB square meter.
Thank You!
