i am trying a composite analysis and i have the problem
*** ERROR # 1000 *** in the input data: Incorrect data in field # 3.
i don´t know how to solve it.
Can you please share the entire .out file?
Hi @tiago3008
Material is missing for plies.
While creating plies make sure you apply material
hi,
I tried what you said and did the simulation.
Now i am doing a simulation of landing gear but after i laminate and i am going to check if i created the plys on the component nothing happens.
I don´t know why.
I created 2 materials and 3mm of plys<?xml version="1.0" encoding="UTF-8"?>
Can you check whether PCOMPP property is assigned to the component?
