Unable to find acusolve result.log file after simulation for post processing
Mudassir khan
Altair Community Member
Hello
I am using Hyperwork CFD 2021version to simulate my CFD project. I have defined the workflow and able to run two simulation succesfully. But unable to find the log file for post processing. My log file occur in text format as "manifold.1.log_acutail". How to convert this file to .log. case file. Is anything is wrong with my software.
Hi Mudassir Khan,
The log file can be accessed from the Solution>Manage>Run Status window, right-click on your process type and select View log file from the pop-up menu.
For post-proccesing the results you select Visualize results.
Best regards,
Alexandru
