hello Expert
I am trying to simulate the granular flow consisting gravel and sand. i created the gravel (size of 7mm) using mutisphere particle method in EDEM and 1 mm sand particle using single sphere. I have little doubts how we can fix the radious of each sphere while creating particle to have resultant mean dimension of particle created should be equal to our particle. For e.g. My gravel has 7 mm effective dia and i am using three sphere in prismatic form to create the prism type of particle. How i fix the radius of each sphere partile creation.
