How can I use DMA config and DMA enable option with STM32 . coude you Plsease any one share detail dcumentation and with multiple real example of implementation of DMA config and DMA enable option with STM32.
Hi Monzur,
Attached one STM32F334R8 DMA Interrupt example.
Like any other Interrupt service routine, You write your logic(read/write) inside a compound block and enable the the compound block with DMA channel interrupt. Memory access call back will be executed as soon as the interrupt triggers.
In the attached example.
- Initialize the ADC1 and enabled it
- Triggered the ADC using PWM1
- ADC result captured inside DMA Interrupt call back.
- Updated the monitor buffer with result.
I will share you more example with detailed step soon.
Regards
Sreejith
