Licence a Machine without user dependancy
How can I license a device for Altair Inspire?
So far, my approach has been to enter the created authentication token into the licensing tool. Afterwards, I can use the product, but if I log in with another Windows user, I suddenly have no access to the software. I get the message saying I don't own a license.
Under authorized machines, while the hostname of the activated machine does appear online, the logged-in username with which I used the authorization token appears under the username. To the best of my understanding, *(ANY) should be listed here instead, allowing multiple users to access the software.
I would appreciate any help!
Best regards,
Markus
Hello Matthieu,
thank you very much for your response!
I believe I've managed to find the right information I needed. However, another problem has arisen. When I activate the machine via the command line ".\almutil -a1auth -code XXXXX -system", I get the message "Successfully authorized this machine with the Managed Licensing system".
It now shows up as "*(ANY)" on the licensing platform, which is exactly what I wanted.
But, when I start the software, I encounter the following message:
"Machine activation token was rejected - Invalid license"
Why is this happening? Shouldn't it work right away now?
Thanks in advance & kind regards,
Markus
Hello Matthieu,
Markus
Did you by chance delete your user token from Altair One?
The solution was as follows:
I had to delete the old authorization tokens from the path "C:\Users\username\AppData\Local.altair_licensing\user folder". "Old" tokens are stored on this device, which leads to an error where, upon launching the software, these old tokens are utilized.
Please see this article for machine-wide authorization .
Matthieu
