I am trying to run a simple tensile test on a piece that I modeled. My part is comprised of different components that required me to use a contact analysis, Another thing to mention is that I'd like to have a uniform boundary condition and load so I must use the rigid body option or else the simulation will not run accurately . I used RBE2 for the boundary condition side and RBE3 for the pulling load side.
This analysis requires a non-linear static analysis, therefore I must input load collectors (SPC and LOAD). For these, I selected a node to implement both the boundary condition and load vector. Since I already used the rigid body command, my understanding is that any node I select on the face will be okay for me select. the nodes I select are the nodes used for the rigid body.
After running the simulation, I look at the displacement contour in the x direction as that is the direction of the pulling load and there it shows that I have a bending moment. Can anyone help me fix this issue?
Attached are photos as well as the hm and output files.
