I have two questions regarding the HyperStudy 2019.1 application.
I am currently in the process of familiarizing myself with the optimization using the application mentioned.
The kinetic model of the lifting arm mechanism of a wheel loader created in MotionView needs to be optimized with regard to the piston forces that arise.
These forces are measured at the translational joints of the indicated cylinders and are available as output.
The input variables are the coordinates of the respective connection points of the cylinders.
Questions:
- When defining the model in HyperStudy, I'm not sure which file to put in as solver input file. I tried different inputs: e.g. "m1.xml", "Kinetikmodell.xml". It mostly works fine for the Write, Execute and Extract TestSteps in Test Model, but when optimizing I get the error message shown below. What can I change to fix this error?
- As mentioned, the piston forces are available as an output. To use this as a data source, I am currently using the mrf-file of the simulation in MotionView. Is this the correct file?
.png)
