What is a SPRING4 and how do we use it in Radioss?
Will you please elaborate on your Question? Please tell me where you are using Spring 4?
Dhanasharee Jadhav
Hi
If you mean /SPRING with more than 2 nodes, there are some applications using /PROP/TYPE44(KJOINT2) that you can model different types of joints.
For instance, revolute joint needs 3 nodes spring, being 3rd node an option to define the revolute axis.
And universal joint needs 4 nodes .
Regards
I wanted to create a 4 point pulley spring (2-pulleys) without having to connect 2 - 3point springs. I assumed Spring4 was that setup. This is not the case?
Hi.
to create 2 pulleys you will need to have two 3-node springs. and use /PROP/TYPE12.
