I am performing a deep drawing simulation on Hyperform Radioss Incremental with shell (surface) models of the components. It is known that a shell model doesn't have geometrical thickness (the thickness is assigned in the property manager). Hence, I have assigned a blank thickness of 2.5 mm, and make the rest of the components rigid.
What I couldn't figure out is that whether or not Die-Punch Clearance (gap) is required in the shell models of die and punch as it is done with solid model.
