I'm just getting started with Motionview/solve and trying to determine the best approach for setting up markers. For points I already figured out how to export a IGES from catia and pull the point data into an importable CSV but I'm getting a bit frustrated when it comes to defining markers. Other than having to determine in CAD the vector relative to the global coordinate system, is there an easier way to create markers to apply loads? I do not seem able to import anything other than solids directly from CAD or hypermesh and all my torque loads are applied to cylindrical bodies with only edges selectable in the definition of vectors that I could then use to create markers, so I'm out of luck using CAD directly even with the option turned on. Am I missing some obvious simple workflow for creating markers from CAD that is not present in the tutorials?
