How to get csv for Load map in Hyperlife for fatique analysis?
can I export it from the hypermesh model?
Thanks
How to get csv for Load map in Hyperlife for fatique analysis? can I export it from the hypermesh model? Thanks
what exactly you are trying to achieve? We can import CSV file format on HyperLife. We can't create a CSV file from HyperLife.
Hello, what exactly you are trying to achieve? We can import CSV file format on HyperLife. We can't create a CSV file from HyperLife.
I want to do a fatigue simulation with a maximum force of 130000N but produce a very small life, I have tried to use time history with a force of 130000N, 17N, 5 N for 300 seconds but still produce a small life
when you say '300 seconds', is it a transient run results you are dealing with? Can you share your file?
