How to get csv for Load map in Hyperlife for fatique analysis?
can I export it from the hypermesh model?
Thanks
I am not sure what exactly you want.
HyperLife is an easy-to-learn fatigue analysis software developed on a solver-neutral framework. It provides a comprehensive tool set for durability analysis, directly interfacing with all the major finite element analysis (FEA) and multi-body dynamics (MBS) result files. With an embedded material library, HyperLife offers solutions for fatigue life predictions under static and transient loading across a wide range of industrial applications.
You could refer to online HyperLife tutorials for more details.
