AcuSolve Log file issue
kalaiselvan_22516
kalaiselvan_22516 Altair Community Member
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.c269fa357993c764cd044d063f084d89.png
Am uable to view the results in AcuViewer, as log file is not available in my working directory and while solving the Auctail window also does not pop up....
But while i meshed the component before solving, Acutail window poped up....What may be the issue for log file missing..
i have attached the snap shot of both solving window and my working directory
  • acupro
    acupro
    edited October 2018
    Although the .inp was written, and the Acusim.cnf file updated (both at 15:47 on 13-10-2018) per the image above, it appears the job did not actually run - at least in the directory Mixing_Elbow_13Oct18 you show in the image.  Is it possible when you launched the first time that you modified the Working Directory in the launch panel?  Can you attach the Acusim.cnf file - or copy/paste the contents - from that directory you show in the image?  You may find faster assistance by contacting your local India support team.
  • kalaiselvan_22516
    edited October 2018
    Thanks for your prompt response..
    I have run the model again, but job did not run again...
    And i have attached the files for your reference... i have also contacted local support team also, but issue has not yet solved.
  • acupro
    acupro
    edited October 2018
    I understand from the support team that you were able to resolve the issue by 'rebuilding' your machine.  This was definitely strange behavior...
