In Flux I want to compute the attraction force of an electromagnet over another piece that is in contact. I know doing it if there is an airgap region (a surface in Flux 2D) between both, but I don't know doing it if there is real contact. I have tried doing it using a line region (type "air gap region") assigned to the line separating both parts but the computation of the magnetic force gives error.
So, is there any way to compute the magnetic force between two pieces that are in contact?
Thank you
