Error 8116: Failed opening scratch file
Faik Fatih Korkmaz
Altair Community Member
Hello everyone,
I am trying to model a buckling analysis in Hypermesh. For this, i have created these cards:
- Linear static loadstep including spc and force
- Eigrl loadstep collector
- Linear buckling loadstep which has linear static analysis STATSUB and eigrl METHOD
Everything seems correct. And I have easily analysis results: displacement, modal results and critical force coefficent.
Hovewer, during some of analysis Optistruct has displayed this message, without any changes in the model:
Fatal Error 8116
Failed opening scracth file "<model folder>/<model name and some numbers>.rs~"
And then i see end of solver output.
I have tried 2 different ways:
- TMPDIR control card: i have created temp directory to other harddisk location which has really empty space. But it did not work.
- Optistruct fix memory option: Before analaysis and optimization, i have set the option to fix memory size. But it did not work, too.
I can not fix this problem.
Thanks for help.
