Hi! I'm currently doing a coupled thermal structural analysis but when I try to get results I get the following errors:
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
Expected INT > 0 or blank, found INTEGER (0).
Incorrect data in field # 4.
Expected REAL > 0 or blank, found REAL (0).
I don't understand what it means and for what I read it is caused by forgetting to assign material to a property which I checked and I did or forgetting to assign a property to a component which I also did. Any ideas?
I will attach my file if it helps. Thank you!
