I'm running into the following error when running OSSmooth (iso surface FEA reanalysis) in HyperMesh/Hyperworks 2020 on topology optimization results from Optistruct 2020:
'BOM comments unsupported in the command.'
Nothing is imported into the model when this message is shown. This only appears to happen when using 2020 HyperMesh and Optistruct, but if one or both are the 2019 version, it works fine. I'm also able to open up the results file in Hyperview without a problem. Has anyone seen a similar issue with a workaround or solution? Ideally, I would like to be able to uninstall the old versions of the software.
Thanks,
Jacob
