I have plug-in the EDEM API of the heat conduction contact model in my model.
The heat conduction contact model I used is the heat conduction API code that can set the geometry as heat source (HeatConductionForGeometry_29July2014.zip), the link is: https://community.altair.com/community?id=kb_article&sys_id=0fadbd1edb3cc590cfd5f6a4e29619cf)
When I looked through this code, I found that this model assumed that the physical radius and contact radius are the same and this contact model can only work on the simulation when these two types of radius are the same.
I am just wondering if I assume the physical radius is not the same as the contact radius, how do I recode this heat conduction contact model? Could you please give me some ideas or do you have any documents or references can help me to figure it out.
Kind regards,
Chao
