I used the volume packing to generate a material block for the geometry. However, I would like to ask if is it possible to generate the bond in the material block (if i use the bonding V2). I try to use the bonding V2 for the material block in the simulation, but I cannot find the 'bond creation time' this attribute in the simulation. The following is the material block for a steel plate geometry, could you please tell me how to implement the bonding V2 in this material block?
Many thanks in advance for your help.
Chao
