Is there possibility to get relative coordinates?
Like COG would be relative to body local coordinate? Or inertia tensor would be relative to the COG or body local coordinate. Then if you override the moment of inertia, you know which direction you are effecting. And with relative coordinates you could set joint relative to object local coordinates.
