Could anyone help me, by explaining the term Mesh Grade factor, Internal Grading in Sim Lab and what happens in background when set limit values. please refer below image.
A smaller grading factor leads to a smoother transition, but higher element count. A larger grading leads to a more abrupt change but lower element count.
If I recall it correctly, usually these Grading factors control the transition along the mesh, controlling how much the element size can vary from one region to another.A smaller grading factor leads to a smoother transition, but higher element count. A larger grading leads to a more abrupt change but lower element count.
Thank you sir.
