I need to write my constraint equation inside the Optistruct using DRESP3 .Is there any possibilities to write using Hypermath and integrate with Optistruct
Please refer below optimization tutorial.
OS-4095: Size Optimization using External Responses (DRESP3) through HyperMath
PS: I am moving this topic to OptiStruct forum.
Thanks for your answers.To be specific i want to use my constraint formulations for topology optimization .Is there any tutorials for that. Thanks in advance.
Hi Gokul,
There is no specific tutorial as such, but you can use the same methodology to use DRESP3 for constrain formulation.
Ok.Whether Optistruct can solve the multiobjective optimization problem (compliance+stress ) for topology optimization problem.
You can do it with HyperStudy.
