Hello! Does anyone have any clue why my model might be flying off into space every time I apply a load on it? I'm using inertia relief (-2) so I'm not sure as to why this is happening.
Any advice would be much much appreciated!
Hi Shindy,
One of possible causes: some parts/elements were not connected well.
To find those parts/elements, you can run a free-free modal analysis(use 0.0Hz as lower boundary of Eigenvalue range) and check the animation, if it's connected well it should have clean 6 rigid body modes.
Thanks.
Xiaolei
