Apologies if this has been asked, but I could not find a specific forum post about this. How do I get my infinite ground plane results to match fairly closely to finite ground results for a simple microstrip antenna? Attached is a FEKO model for the infinite ground plane version. Am I setting this model up correctly with a wire port? If so, how would I translate that to a finite ground version with finite substrate, in this case Megtron?
Edit: I should mention that, I have been modeling this antenna for quite some time and just recently found that the infinite and finite ground planes' impedance/reflection vary by a few dB in the 77-81GHz range. The gain patterns vary also, but that is manageable and makes sense.
Thank you for your help,
Lucas
