Dear Experts,
I am currrently carrying out thermal analysis in AcuConsole on a photovoltaic panel composed of five different layers (Glass cover, encapsulant, silicium cell, encapsulant, Backsheet). I want to consider thermal radiation on the front& back surface of my PV panel according to the following equations for the front and back surface, respectively:
I read in the AcuConsole training manual that calculation of radiation is only possible from surfaces of fluid mediums but I have no fluid in my simulation setup. Therefore my questions are:
1.) Is there any other possibility to implement radiation without a fluid volume (i.e. setting heat flux (boundary condition) to -100 W/m^2 on the corresponding surface)?
2.) The equations above are dependent on a value which has to be calculated by the processor (Trear and Tfront). Is it possible to formulate such boundary conditions that depend on values that will be calculated later by the processor (AcuSolve)?
Thanks in advance!
