please, read the help for 'Prestressed Linear Analysis' and also take a look at the example 'OS-E: 0305 Preloaded Modal Frequency Response Analysis'
Essentially you run a linear subcase first, and add it as STATSUB(PRELOAD) to the next loadcase.
I have performed MFRA with pretension stat sub, i got the following error.
Internal programming error.
delete detects overwriting of data block:skge
DATAMANAGER ERROR IN SUBROUTINE "DATAMD"
