Good afternoon,
I'm using FEKO 2018 and I'm trying to create a hollow cylinder with an aperture at the top. For this purpose I created two cylinders, substracted one from the other to create the hollow inner space and subtracted a cuboid to create the aperture. Unfortunately, after meshing, the mesh quality is very bad compared to a full cylinder of same dimensions.
How can I achieve a better mesh quality? I also recognized, that the hollow cylinder seems to be meshed both outside and inside as the number of mesh elements is much larger. Can I make the cylinder's surface infinitely thin somehow, in order not to mesh the cylinders inner and outer surface?
