Hello everybody,
I encounter a little problem in the 2021.1 version of Inspire.
Not long ago, I created PolyNURBS which appeared in a component of the tree as "PolyNURBS Part 3". I saved it and, when I reuploaded it on Inspire, it disappeared.
What I mean is, the component "PolyNURBS Part 3" is still in the tree but, on the view, the arms are not visible anymore and I can't make active this "PolyNURBS Part 3".
In fact, when I go to 'Enveloppe", I cannot modify this PolyNURBS and it automatically creates another PolyNURBS if I for example try to create new arms.
This is kind of a disturbing problem because when I export the model as .stl format, the arms are not there whereas they appeared in the export before.
Thank you for your help,
Arthur Abina
