Hello there,
I am inexperienced and trying to perform 3 point bending tests on composite panels with Radioss for formula student. I already had some advice but I'm stuck again. I'm trying at first to do the test on only a few plies. Later I will try to add honeycomb etc.
By the way, when I'm at this step, should I make a contact between the upper shell plies, the honeycomb in Solid and the lower shell plies?
Regarding the current model, I can't get it to work. First I got the following error:
--- PROPERTIES 1 ERROR(S) |
|--- 1 ERROR ID : 760 |
| ** ERROR TRAPPED |
Afterwards, I modified some properties but I still have errors. I don't understand which parameters to modify and which are my errors:
Thanks a lot for your help
PS: I am working with RADIOSS 2019 in my school, I can't open your edit 2020 file
