I am working on hydraulics and stuck with a bit of confusion. We give speed input to the pump using "ConstantSpeed block". But the problem is, my speed is dynamic, coming from engine curve depending on the torque of each pump. I am able to take torque from the pumps and get respective speed from the engine curve. But the value of speed is just a constant which pump cannot understand it is the RPM, unless i feed a constantspeed block. Is there any way that the speed value coming from the engine curve can be fed to pump so that, pump understand it as speed input?
