RegEx Trapping Methods (\r \n)
Jordan_22422
Jordan_22422 Altair Community Member
edited September 2019 in Community Q&A
I was wondering if there is a way to leverage the RegEx characters \r or \n while trapping data from a PDF source.  I have been unsuccessful up this point and am not sure if anyone out there has figured it out.  The first line I want to trap starts with an (H) and the second line starts with an (I), however I do not want to split up the detail trap to also capture (I) and I also do not want to only trap the (H) line and then set the trap to multiple lines.  I need it to be all in one (this way will decipher between an alphabet (I) and a roman numeral (I) with the data I'm using)
Jordan Matusik
Welcome!
  • CPorthouse
    CPorthouse
    The short answer: No.  When using regex traps, all white spaces (line breaks, tabs, carriage returns, etc.) are converted to spaces in the trap window.  That means the regex characters like \n, \r, \t will not work but the \s character will.
    If you do trap multiple lines, you can split the data in the table view using the \n regex character.
    Can you distinguish the alpha letter "I" from the roman numeral "I" in your data?  The onscreen presentation makes them look the same.
    I know you said you did not want to break up the lines, but one possible workaround would be to capture those lines as a detail and then with some transformations and a merge statement you can join them together with line breaks to be one column.
    Chris Porthouse
    Senior Implementation & Integration Engineer
    Altair
    Original Message:
    Sent: 09-17-2019 03:05 PM
    Subject: RegEx Trapping Methods (\r \n)
    Jordan Matusik
  • Jordan_22422
    Chris Porthouse
    Altair
    Original Message:
    Jordan Matusik
    Thank you for getting back to me.  There really is no way to distinguish a letter "I" from a roman "I" unfortunately.  I had a solution if I was able to use carriage returns in the trap window.  While I have you here, when using regex patterns within DPS, is there a way I can reference a quotation (")? Given you open and close a regex pattern using quotes, I have had trouble using a quote within the pattern itself.  I have found some workarounds, though it would be easier and more efficient to just reference quotes as they appear.
    Jordan Matusik
    Financial Consultant
    Immersion Consulting LLC
    MD
    440-622-1202
    Original Message:
    Sent: 09-18-2019 07:50 AM
    Chris Porthouse
    Altair
    Original Message:
    Jordan Matusik
  • CPorthouse
    CPorthouse
    Jordan Matusik
    MD
    440-622-1202
    Original Message:
    Chris Porthouse
    Altair
    Original Message:
    Jordan Matusik
    If you are talking about a regex trap (report design) you should be able to just use the double quote or you can also use the backslash (\) as an escape character.  If you are talking about within a formula/calculated field using one of the regex functions, i.e. RegexIsMatch, you should include your regular expression inside of single quotes (' ').  Again, you can either use '"' (single, double, single) or escape it '\"' (single, backslash, double, single).  Hope that helps.
    Chris Porthouse
    Altair
    Original Message:
    Sent: 09-18-2019 10:26 AM
    Jordan Matusik
    MD
    440-622-1202
    Original Message:
    Chris Porthouse
    Altair
    Original Message:
    Jordan Matusik
Welcome!
Welcome!
