I would like to model honeycomb cardboard and corrugated cardboard as homogeneous and detailed geometry. Which material cards should I use ?
Regards.
You could use LAW28 (Honeycomb)
tension/compression/shear tests for all dofs are necessary to fill the cards in for this law
You could use LAW28 (Honeycomb) tension/compression/shear tests for all dofs are necessary to fill the cards in for this law
Thank you for your reply.
