Hello Everyone.
I have a gear setup in motionsolve/motionview. I used tranmission gears up to the differential.
I used RIGID 3D Contacts for the gears. Once i solved it, the gears doesnt produce a smooth transmission of motion. The only gear that shows smooth rotation is the Pinion gear which is attached to the motor (the gear that I applied MOTION (700RPM))
What i Mean is, the Pinion Gear Shows a uniform angular motion 700RPM but the succeeding gears seems bouncing with each other and produces a non constant speed. (its like rotate- then stop then rotate again then stop). I thought of editing the CONTACT from IMPACT to POISSON and Reduce Coefficient of Restitution to avoid the bouncing but Im not sure if what im doing is correct.
How to avoid this? Thank you for your answer. GodBless
