Dear friends,
Good morning, I have a situation and I don't know how to solve. I think you can have a solution.
I have a structure composed of beams and surfaces (beams are in the same planes than surfaces). I want to consider the connection between the two components: at this time I have meshed yet beam elements (so I have their nodes in the model), but now I want to do the next: that surfaces will be meshed and their nodes will be coincident with beams' Also I want to know if this is the only thing that I have to do to consider the connection between beams and shells or if I have to define something else.
Thank you very much for your attention. Best regards,
JJJ
