May I ask your favor regarding contact and reaction force?
1. Regarding contact (penetration)
1-1) I am solving excavator model which is passing over blocks. As you can see in below picture (section cut view to see penetration) there are several penetrations. I solved several times by changing contact stiffness K (F=K*z^exp) but those were not worked properly. I tried within 1000~3000 for K and time step 0.0005~0.0003 (too long solving time if use 0.0001). Can you advise me how to reduce penetration?
1-2) As you can see in picture in below right, too much penetration was made for 0.01 second. There are around 50 sub steps between 4.94 and 4.95 second. And average step size is 2.44E-5. Should I reduce step size more? or is there any reason and countermeasure for this kind of result?
1-3) I saw Advanced option panel for contact in MotionView. Is this helpful to resolve above problem? I tried with checking them but I was faced an error. Could you explain me the function of the option? or Could you let me know the link describing detail explanation?
2. Reaction force
I am comparing Roller's reaction forces between test and simulation. Reaction force by simulation is 2 or 3 times higher than that of test. All parts are composed by rigid body, including ground. Length of ground is around 30m and I installed bushing(3E5N/mm for translational, 1E15N/mm for rotational) on the ground to reduce reaction force but it was not enough to reduce reaction force (ground deflect too much if use weaker bushing). Do you have this kind of experience? and could you share the experience how did you resolve this kind of problem (very higher force than real)?
Thank you and Merry Christmas & Happy New Year.
