My computer has 32 cores logically (16 cores) and 96 GB RAM memory. I am running my model by assigning 24 cores but it uses 30~50% of CPU when seeing the Task Manager. I think that MotionSolve should use 75%(24/32) of CPU or 100%(24/16).
1. Could you tell me the reason of low CPU usage (less than 50% of RAM is being used) ?
2. Is there any function in MotionSolve that calculate/estimate optimal CPU or RAM memory depending on model size?
3. Is there no way to use GPU?
Thank you in advance.
Best Regards,
Yoseob.
