Hello everyone,
I would like to know about your experience plotting comulative Archard wear graphics. I have succesfully calibrate my iron ore sample from a peruvian mining. My thesis is realted to the comparison of the wear over the chute liners and the receiving belt from two solutions. In that sense, I have completed the next steps:
First: I have imported the actual chute solution, it is located next to the first crusher zone.
Second: It is a 100 seconds simulation with surface energy p-p, JKR-V2 and Archard wear model. The feed rate is 988 kg/s with a 4.2m/s belt speed.
Third: The next figure correspond to Archard wear coloring texture with just a prototype displayed.
Fourth: The last figura correspond to the Archard wear cumulative histogram over the receiving belt.
So, my question remains over how can I get visual results like the down below. It is necessary high programming skills? Can I get those graphics with the analyst? Do you know about a base tutorial to start with .dll file extensions? What do you recommend?
I will really appreaciate your help and your time.
Un cordial saludo para toda la comunidad de ALTAIR - EDEM
