Dear Sir/Madam,
I am using your WinProp software, version 2023.1.2, for my research project titled "Analysis of Vehicle-to-Vehicle and Vehicle-to-Infrastructure Communication in an Urban Environment." The area for which I am defining communication is approximately 270 x 270 meters. The main communication occurs within a single intersection, with street widths ranging from about 10 to 15 meters. The vehicle-simulating objects used in the project vary in size, with dimensions ranging from 1.8/4.5/1.8 meters (height/length/width) to 4.1/15/2.55 meters. I am specifically analyzing a blockage scenario.
I have a few questions regarding the pre-processing settings for the IRT model.
For such a large database—where time-varying simulation requires the use of an internal database—the default parameter settings, such as:
- Minimum wedge length: 0.01 m
- Panel width for standard walls: 2 m;
- Panel width on predic: 2 m
- Wedge segment length: 2 m
- Width of tiles at predicion planes: 2 m
- Spherical zone (disabled);
- Exclusion of triangular objects (disabled);
generates a database of approximately 14 GB for just one second of simulation, and I would like to consider at least 15 seconds for the scenario.
Therefore, I would like to reduce the database size significantly. What settings should I use to ensure that the approximation generated during the simulation remains as close as possible to the real-world scenario, while keeping the database size much smaller?
Best regards,
Mateusz
