we were trying to install hwDesktop2022.1_win64, but we receive an error after the initial checking (InstallAnywhere is preparing to install...).
Attached you can find the error.
Best Regards,
Rui Ferreira
Are you trying to install on Win11 machine?
you could try the newly released hwDesktop 2022.2 and chek if the same happens.
I believe this is related to some incompatibility on Java with Win11.
Are you trying to install on Win11 machine? you could try the newly released hwDesktop 2022.2 and chek if the same happens. I believe this is related to some incompatibility on Java with Win11.
A similar issue was reported in this other topic, with a solution that might help (not guaranteed).
https://community.altair.com/community?id=community_question&sys_id=fa8748ccdbcfd550cfd5f6a4e2961992
