Dear friends,
Good morning, I am solving a modelo and when I run it I have this message:
*** ERROR # 153 ***
Exactly zero pivoting encountered during Numerical Factorization;
the model may have rigid body mode.
Solver error no. = -514
spc set id = 1
index = 1
Possible reasons are:
1) insufficiently constrained model,
2) having rigid body mechanisms within the model,
3) extremely ill-conditioned rigid element sets,
4) extremely thin shells (as used for skinning) that have MID2/MID3,
5) gap elements with extremely high stiffness (KA, especially KT or MU).
6) extremely high Poisson's ratio in hyperelasticity material definition.
Check the model and rerun the problem.
(MECHCHECK may be used to find the rigid body modes. To do so,
change the input to be an eigenvalue analysis and add MECHCHECK.)
(WARNING: results obtained with MECHCHECK cannot be used because
the model is changed internally.) This error was detected in subroutine bcsmtxfct.
I can't find the way to define the MECHCHECK option (anybody could please share a detailed tutorial of it? Because I define an EIGENVALUE analysis but then I don¿t kno how to define the MECHCHECK option.
Thank you very much for your attention. Best regards.
