Hi everyone,
I´m simulating the magnetic behaviour in a varying frequency on some cores but I've got a restriction.
I have understood that, if I want to simulate a core in a certain frequency to get core losses, I would have to introduce the B(H) curve in the material expecifications (for the same frequency).
I use to fill the 'Isotropic Spline Saturation' gaps with 'Sine wave magnetic field', adding the 6 Modified Bertotti losses coefficients.
But what if I got B(H) information for only 1Hz - 10kHz range? How can I calcule the losses for 150kHz?
Is there any way to draw upon of Steinmetz or another technique in FLUX?
Thanks
