Hi.
I want to input material properties in curve form.
Could you tell me how to input material properties as curves
Hi Haveto,
Could you please elaborate on the material properties you have available?
Below are a couple of commonly used material cards and their applications:
MAT1: Defines the material properties for linear, temperature-independent, and isotropic materials.MATS1: Specifies stress-dependent material properties for use in applications involving nonlinear materials. This card can be used to define elastoplastic or nonlinear elastic materials.MATT1: Specifies temperature-dependent material properties on MAT1 entry fields via TABLEMi or TABLEG entry.MATHE: Defines material properties for nonlinear hyperelastic materials.
Regards, Sriramanuj Prabhu
