Hello everyone,
For my master’s thesis, I am currently conducting quenching experiments with aluminum extrusion profiles. The profiles are heated to 550°C and then quenched in a water bath. The profiles are always submerged exactly 90 mm deep, with the water column being 120 mm high and the water temperature set to 20°C.
Now, I need to simulate this process and compare the temperature curves. Since this is my first time working with Hypermesh and I have very little experience with simulations in general, I could really use your help.
Here’s what I’ve done so far:
- I designed the profiles in Inventor and exported them as a STEP file (profile height: 90 mm).
- I imported the file into Hypermesh and created a box to represent the surrounding water (dimensions: 120 x 70 x 70 mm). The water surface and profile surface are aligned at the same level.
- Using Boolean operations, I set up the scenario so that the profile is hollow inside and surrounded by water on the outside.
- I assigned the materials and initial parameters and created a coarse mesh for an initial test simulation.
The problem: When I run the simulation, the temperature curve looks strange. The temperature barely decreases.
My question: What might I be doing wrong? Should I approach the simulation setup differently, or is my current approach basically correct?
I’ve attached a few screenshots to better illustrate the situation.
Thank you very much in advance for your help!
Best regards,
akinh0
