Good night to everybody,
I want to know how to obtain modal masses and participation factors for each mode obtained. Also I want to know how I can animate deformations of one mode.
Thank you very much and regards,
JJJ
Hello JJJ
I have attached demo video on how to obtain modal masses and participation factors for each mode obtained & also how to animate deformations of modal results.
Kindly let us know if you have any concerns.
Thanks & Regards
Nantha Kumar N
Hello, thank you very much for your response. My recommendation is that would be similar to SIMSOLID to pos-processing data calculated. One more thing: what I see is that Solve options disappear from the ribbon (initially, when start the software, you can see then). Regards.
